User Voicemail versus Group Voicemail
basiluk11
Beginner
Beginner
Can anyone tellme the functional differenceis (if any) between group and user voicemail accounts please?
...Jon.
basiluk11
Beginner
Beginner
Bump
Christopher Edgeworth
Frequent Contributor
Hi Jon,
The voicemail capabilities are the same for a group mailbox and a personal mailbox.  If the group mailbox is for a huntgroup you will probably want to provision a group mailbox monitor button on the phone(s) so you will know when there is a message.  Alternatively, you can use the voicemail to e-mail function and e-mail the voicemail WAV file to multiple e-mail address targets.
When there is a group voicemail provisioned on a user's phone you may have to educate the end use how to look at the LCD display next to the line button to see if there is a message waiting on a shared extension vs. on the private user extension.
Hope this helps.
Chris
Hi Chirstopher,
Did you mean setting up the huntgroup line as a second line when you mentioned provisioning a group mailbox monitor button on the phone(s)?
James
Hi James,
A hunt group extension is a virtual extension, it doesn't actually exist on anyone's phone. When you call the hunt group extension it will forward/fork the call to one or more real extensions either in sequence or simultaneously. While the huntgroup is a virtual extension, there is actually a real voicemailbox created for that extension. In order to monitor if there is a message for the huntgroup mailbox, we needed an intuitive way to do it so that it didn't interfere with other real extension based voicemail notifications. To do this we created a new button that monitors the group voicemail box (MWI) and also acts as a speed dial to retrieve messages from the group mailbox.
Hope this helps clarify.
Chris
