11-09-2009 06:21 AM - edited 03-21-2019 01:45 AM
How many channel o port are available in a SIP trunk on UC500?
11-09-2009 06:36 AM
SIP Trunks are generally bandwidth assocated. You can have as many G.711 or G.729 codec calls that are negotiated and fit.
You can do this all over a few DIDs or DIDs for every phone in your system.
Not sure if this is what your asking?
Steve
11-09-2009 07:47 AM
I have a WAN Link of 10 Mbps. How many simultaneous calls can be established?
UC500 ------> (WAN Link 10MBPS) ------> Trunk SIP --------> ITSP
11-09-2009 08:23 AM
You are supposed to be limited to the license that you bought, for instance, an 8U box can handle 8 calls. A 48 U box, 48 calls. If you plan on having the calls go to AA, be aware of the platform limitations in calls to AA and VM. You have 6 sessions there on a UC520.
By bandwidth alone you are looking for about 80k per g711 call and 24k per g729 call. There are other factors including what else you are doing on the box. If you have a lot of VPN traffic, this could be less as it will take away some CPU cycles.
Another factor is how good is your QoS on the link? Is the link 10Mbps up and down? What else is going on the link? QoS can be setup outbound on the router, but you need to make sure you also have inbound QoS through your ITSP as well. I hope this helps.
