When I call out on my sip trunk I would like my main company number to show insead of the sip number. Does anyone have a step-by-step on how to do this? Thx.
How would I get the SPA962 to generate CoS values without configuring the phone to use a VLAN so the simple switch it is attached to that doesn't understand multiple VLANs but DOES understand CoS values provides the proper treatment to the traffic fr...
How can I change the outgoing caller-id on my SIP trunk? I forget the command and where to do it. Right now, the name of the phone gets sent out instead of the company name. I want the company name to go out on all phones. Thx
Hi,Question Part 1:I am running the newest firmware v5.2.10 on my SPA-2102 and it hung twice during a one week period. I noticed it hung after my firewall logged either a TCP SYN FLOOD attempt or a Smurf Attack attempt, I caught this happenning just ...
Hello,I actually use an SPA2102 with 2 SIP accounts. The first one, on the line 1 use QOS by tagging RTP packets :Network SettingsSIP ToS/DiffServ Value:SIP CoS Value:[0-7]RTP ToS/DiffServ Value:RTP CoS Value:[0-7]Network Jitter Level:lowmediumhighve...
HiI have just set up a SPA3102 on my internal network, and have connected it to the PSTN.I want to be able to route incoming calls on the PSTN to a IP phone (a Snom 360), and also make outgoing PSTN calls on the Snon. For the moment, it is just one I...
I using a SPA 8000 with a Panasonic wireless phone system (pots)Can I upgrade to a SPA 9000 and still use the the 8000 with the 9000 for the pots lines?I need 5 pots lines with the SPA 9000.Steve
Hello!I have a problem with this error message java.lang.NullpointerExeption in cca 2.0.(1).I attached the config for UC 500.Can anyone help me!regardsSOLO
I have heard details about Cisco Unified CME 8.0 on the following page:http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/feature/guide/Cisco_Unified_IPPhones_69xx_Series.htmlFeatures added to Cisco Unified CME 8.0:Support for Cisco 6900 series phon...
by mistake I deleted the flash memory I reinstalled the IOS in order to install the software package UC520-7.0.3.zipthe problem is when I attempt to upgrade using the Cisco configuration asistant application in the 49 per cent of the ipgrade procc...
Hey everyone ,I have a working 2 site (mutisite setup , setup with CCA 2.1) All features work fine except I have a very interesting problem.Internal calls and transfers work site to site. But when I get an incoming call via SIP, I can not transfer ...
Hi all, I've a problem and already checked the config - I think - like a previous discussion on this forum and until now I cant make a conference call with two outgoing bri calls.When I try to establish the conference the UC500 says cant complete th...
This is long over due because I've been living with this issue for a while.Time to ask.I have a SPA3102 with a local VoIP service. I do not have it attached to an active PSTN line. For some strange reason the unit is resetting itself. After 4 minutes...
Hello,I have a customer who is in the Home Health industry and they need their AA to be accessable for callers who are physically disabled.Right now, they have a bunch of options for callers; press 1 for this and 2 for that, so on and so on. But if a...
also happens when you try work on various aspects of the firewall / nat.
