Some questions about UC540
philippe.valin
I get my first UC runs OK, but now I would like to customize it. So I have few questions how to do. I hope someone could give me some tips, no links to official documentation, please.
How to import audio files for BACD, MOH, and Voicemail ?
How to send an audio file in attachment for voicemail ?
Fax 2 mail or/and mail 2 fax option ?
How to install and use Smart call connector ? What is the difference between versions ?
How to adjust the hour GMT+1 with CIPC device ?
How to do secured remote admin with CCA ?
Thank you helping me.
6 Replies 6
Steven DiStefano
Open separate threads for each topic for more details please....
MOH can be done with Office Manager (OM): https://supportforums.cisco.com/docs/DOC-9839/
Voice mail is done from the handset of the phone
BACD is done from CCA GUI under BACD
IMAP Integration to send voice mail to email
T37 Fax on ramp/off ramp not supported in CCA 2.2.5.  It should be in 3.0
Smart Call Connector product suite: https://supportforums.cisco.com/docs/DOC-13190
Synchronize your system in CCA and this should take care of this.
Enable or Disable Telnet/SSH from CCA GUI.
Hello Steven,
OK for MOH with officemanager, I'll try this.
My question about BACD was: is it possible to import wav files instead of using the simple CCA prompt maker ?
How to do imap integration under CCA ?
So wait and see for Fax option...
For CIPC ntp sync under CCA, it doesn't work for me, all IP phones are sync but not CIPC...
I tried to connect with CCA on my public IP, but it doesn't work, the UC is full NAT behind my firewall.
Thanks for your feedback
Anyone could help me more ?
Philippe:
Steve mentioned in a previous post:
Hence, please use a single post for each of your issues which you have questions and need help with.  This is for ease of archival, and makes it easier for other users which may have the same issues down the road search and find similiar issues previously asked with ease.
Be as specific as you can with each post, and the troubleshooting done, and we can take a look at those issues one-at-a-time.
My question about BACD was: is it possible to import wav files instead of using the simple CCA prompt maker?
You must import an .au file in a very specific format.  You can drag and drop it onto the UC560 in CCA:
https://supportforums.cisco.com/message/3111493
Here is the technical enablement lab on implementing IMAP on the UC500:
https://supportforums.cisco.com/docs/DOC-9785
Here is a good post about troubleshooting the time on CIPC:
https://supportforums.cisco.com/thread/2020957/
Your firewall could be blocking some traffic.  Telnet, TFTP, and FTP are protocols you definitely need open.  I would try opening it all the way and scale back once it is working.
Thank you very much Adam.
Now, I think I can migrate my trixbox to UC with full features I need, except announcement option, but I use BACD instead.
Great job.
