SPA-500DS programming. Does anyone know how we can program the keys to connect to extensions
mkalms001
We have a number of SPA-509G phones with SPA-500DS attendant consoles attached and want to use them on an Asterisk based SIP system. everyone keeps saying that the soft keys on the 500DS should be programmed:
fnc=blf+sd+cp;sub=name@$PROXY
It doesn't work! It can't log in because it needs a password obviously. Can anyone give us the correct commands and syntax to make it work please
matthewkhil
It shouldn't need any username or password as it just uses the credentials and sip proxy from ext1 tab.
I've attached a screenshot of my setup - working fine with 8 spa500ds attendant consoles on SPA504g phones and asterisk 1.8.
Maybe you need to add ';nme=joe bloggs' at the end of the speed dial - not sure if it is compulsory.
Also you might need to add hints to your asterisk dialplan to get the blf (lights) working. The blf component of your speed dial will attempt to subscribe to an asterisk hint.
Checking you are on the latest firmware for the phone couldn't hurt either.
