SPA 504G Transfer stopped by incoming calls
AgbangaKarite
I've been having some trouble with my company's recently adopted PBX system and our 504G+S500 and found this post in another discussion (which was posted in the wrong area).  I've reposted it below and am hopeful that this community might be able to offer some suggestions or advice that could push me to find the answer.  Any help would be appreciated!
"Hey Guys,
So I have a receptionist with a Cisco SPA 504g that has a SPA500 attendant console attached to it. Here is my problem:
- Call 1 comes and receptionist picks up Person A
The call is for Person B, but she has to do an attended transfer, so she
hits the transfer soft key, followed by Person B's 4 digit extension. Person B picks
up and says he is available to take the call.
- In the meantime, a second call comes in Person C.
While the second call is ringing, she can no longer hit the "transfer"
soft key to send the 1st call to Person B. She has to wait until the call stops
ringing for the button to appear.
To handle this I told my receptionist to tell Person B that a call is coming in and that she will transfer Person A in a minute. She then need to hangup on Person B. Next is to pick up Person C and put him/her on hold. Then go back to Person A and transfer him/her again.
Is there a better way of doing this? It is fine if there are 1 person is calling but becomes a pain when 2 or more call in at the same time. It becomes more difficult.
Also is there a firmware release that fixes this problem? It owuld be nice if the new call came in and she could press the down or up arrow and get the transfer button back.
Thanks for all the help."
I am also using Asterisk-PBX and Queue is working perfect for me and I hope it will work for you as well. We also have a policy to have a receptionist answer all the calls.
Could you explain this "Could we configure it to allow people to dial out without an announcement? " so that I can help you further. Also, I am notsure if this thread is good to answer about Queues. You can open discussion in Freepbx which is what I am using.
Let me know.
31 Replies 31
rbordner
James,
Here are some options to try with your PBX:
1) On phone tab change ‘line navigation’ from ‘per line’ to ‘per call’.
2) Edit Programmable Soft Key Ringing State and add xfer option
Then you can use the up and down arrow to move between the two calls and select the softkey option valid for that call.
Randy
Hey Randy!
I'll be trying your suggestions today and report back on what works most likely before the end of the day.
Thanks for your help!
Alright, I have worked on this a bit this morning trying to get it running smoothly.  I was interested to see that our 'line navigation' setting was already set to 'per call'.  I DID however modify our Soft Key Ringing State field to say "answer|1;ignore|2;xfer|3;toggle|4" in the hopes that it would add the "transfer" option to the softkeys while it was ringing.  Oddly enough, neither the "toggle" or the "transfer" softkeys appear when the phone is ringing (to be clear, the 'toggle' line was already present but that key has never appeared either).  I did be sure to save my changes and the phone reset itself.  The configuration panel is currently reflecting the changes I made.
Is there any error in my syntax or other reason that it may not show these keys with these settings?
As an afterthought, were the transfer option to be present on a ringing call, would that allow me to complete a transfer I have already begun on another call, or prompt me to transfer the currently incoming call?  Seems like it really could go either way.
Thanks again,
James
Just a friendly reminder that this issue is still presenting some serious challenges for our customer service department.  Any reccomendations or work arounds that ANYONE may be able to suggest would be very valuable to us.
James
Interesting problem
This is not the best solution but alternatives.
We have an attendant that actually has two phones in a ring group.
Or if the PBX asteriskbased you can try installing FOP2
Please do share your findings.
Best luck
  Unfortunately we do not have the phones or resources available to open up another phone/operator to call recieving (one of the reasons we went with these phones was that we thought we would be able to handle calls more efficiently), but we DO have Operator Panel 2.  I have used OP2 to perform some basic functions, but i'm not sure how it would be able to aid me with this particular issue.  What exactly do I need to do in OP2 in order to select the "line" that needs to be transferred and transfer it successfully?  How do I do an attended transfer through the OP2?
Thanks for your help,
James
This works fine with the 504g but still have the issue with the 502g using multiple call appearance, I am unable to toggle between the calls.
John
deepakitkar
I tried a different approach but it is totally from the PBX side. I created Queue and the 2nd call will always be in queue before receptionist transfer the 1st call. As soon as the 1st call is transferred, 2nd call rings and so on. What pbx are you using?
-Deepak
That could be a usable work around!  I'm on an Asterisk-based PBX with some added UI and access features.  Our corporate policy right now is to have a person answer the phone 100% of the time, and i'm not very familiar with queues.  It should essentially answer incoming calls and direct them to the recieving line when it becomes available, correct?  Could we configure it to allow people to dial out without an announcement?  I know you aren't necessarily going to be intimately familiar will all Asterisk PBX's, but thought I would ask in case.
Doing a little bit of reading it looks like a queue certainly could help prevent the situation that is causing this problem, but I want to be sure we can implement it without reducing the quality of our customer service or acting outside our company policy.
Let me know.
Let me rephrase: If a incoming caller is in the queue, do you think it would be possible for us to enable them to dial one of our extensions and bypass the queue without using any automated voice menus?
The scenario we want to avoid is this:  One of our employees calls in to tell us they are running late, but there are two calls in the queue.  The employee knows their supervisor's extension, so we want them to be able to dial in to them, but we do not want customers dialing directly to extensions because they tend to flood single lines and misdirect their own calls.
Do you think it could be possible to enable callers to dial extensions without a prompt or an automated voice recording/menu?
Also, is freepbx a separate forum, or a subtopic?  Could you provide a link?
Thank you very much for your help!
James
I think it is possible. Join the freepbx community forum. Once you create the discussion thread there, reply to this thread here.
http://www.freepbx.org/forums
Alright, so i've tried more than once to register with that forum, but I am not recieving the confirmation emails in any of the addresses I have tried so far (or in their respective filters or junk mail folders).  I am still trying to work with the queue settings, but it looks like the powers that be in my office may heavily lean torward just replacing the phone and hoping for one uneffected by this problem.
I'll let you know how any of the fixes or swaps we do turns out.
Queue will work for sure. I have already implemented this in our both facilities. Let me know if you need any help.
