ā09-14-2012 04:02 AM
I am using Cisco SPA 525g, but when i apply DND from the terminal, it does not sync with the Broad Soft.
I am using firmware: 7-5-3.
Any idea, how to sync the DND with Broadsoft, when applied from terminal.
Shivam
ā09-24-2012 01:37 AM
Hi Shivam,
Have you already enabled the following parameters under 'SIP' when youre logged on as admin :
'Hold Package'
'Talk Package'
'Conference Package'
You might also need to delete all the entrys at 'Vertical Service Activation Codes' under 'Regional'.
Joƫll
ā09-24-2012 04:31 AM
Hi Joell,
Yes other packages has already been active.
Cisco 504G is working fine. The only issue is with 525G.
Shivam
ā10-30-2012 07:33 AM
