SPA 9000 and SPA 8000 Compatiable?
Stephenzap_2
Beginner
Beginner
I using a SPA 8000 with a Panasonic wireless phone system (pots)
Can I upgrade to a SPA 9000 and still use the the 8000 with the 9000 for the pots lines?
I need 5 pots lines with the SPA 9000.
Steve
Alberto Montilla
Dear Sir;
SPA8000 ports are FXS not FXO, so cannot connect lines to it. You would need 2 SPA400s to connect 5 lines (each SPA400 supports 4 FXO ports) in addition to the SPA9000.
Alberto
https://supportforums.cisco.com/docs/DOC-9857
I did some research and found this, it looks like this will work
Steve
Alberto Montilla
Dear Sir,
Yes, that will owrk, but please note this is connecting phones, not lines...outbound is always using VoIP.
Alberto
Recognize Your Peers
