SPA ringtones utility
asmodaisda1
This link is dead https://www.myciscocommunity.com/docs/DOC-6672
This program is not present in CD
Or find this program ?
Thank you for help
cindy toy
Level 7
Level 7
Please go to this link instead: https://supportforums.cisco.com/document/37331/ringtonezip
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
cindy toy
Level 7
Level 7
Thank you :-D
YOU ARE THE BEST
You have solution for have ringtone that exceeds 6 seconds ?
Read Custom Ringtone problems
Ringtones longer than 16080 samples may or may not work for you. It may depend on phone model, firmware version, current memory usage and overall phone state ...
You should not believe it will work all the times.
Thank you :)
