07-08-2016 03:01 AM - edited 03-21-2019 10:34 AM
Hello everyone
I am quite a tech savvy person, however, I'm completely in the dark when it comes to communication systems. So apologies in advance for the possible naivety of my question.
I have bought a SPA112 2 port phone adapter in the hope that I can connect a burglar alarm to a VOIP system via my LAN.
The reason is that we abandoned our analog landline a couple of years ago, opting for mobile (cell) phones and Skype instead.
My questions are these:
Can the SPA112 be used to make an outgoing call from the burglar alarm to my cell phone?
Can the SPA112 do this via Skype or will I need to join another VOIP provider.
What settings do I need to change to make this work?
Please be patient with me.
Many thanks
Seb
Solved! Go to Solution.
07-08-2016 03:11 AM
Yes. This is how I set my alarm up with an SPA 122.
Voice service provider.
07-08-2016 03:11 AM
07-08-2016 08:05 AM
Thank you very much.
I'm considering using a cheap outgoing calls only VOIP like this http://soho66.co.uk/7456/all/1/Single-User-VoIP.aspx
Hopefully that will work.
Is there anything I should know about setting up the SPA112?
Thanks again
Seb
07-08-2016 04:22 PM
Upgrade the firmware of the SPA112 first before making any configurations. That's about it.
07-09-2016 12:52 PM
Absolutely spot on. Worked without issue.
