SPA232D Dial Plan Suffix
Does anybody know if it is possible to add a suffix '#' to all outgoing numbers in the dial plan?
I would like to dial '01xxxxxxx' but I would like to the ATA to send 01xxxxxxx#. I am using a wireless modem/dialler for outbound calls and the dialling takes 30 seconds unless a '#' is added to the end of the number.
My dial plan uses '01xxxxxxxS0<:@gw0>'. I have tried using 01xxxxxxx#S0<:@gw0>, but it doesn't seem to work, even if I dial 018258675# for example.
Thank you if anybody can help.
You can add a digit with the sequence <:x>
I would try '01xxxxxxx<:#>S0:@gw0'
without the ' ' of course
Actually setting the Interdigit Short Timer to zero is not needed because you will have entered the required digits.
Your test didn't work because using the # as you did is a signal to the SPA232D that the number is complete and is to be transmitted.  They mention this feature on page 231 of the Admin manual.
Thank you again Howard.
That seems to work well. I have spent days looking for that solution, without success.
Also, thank you for the advice on the inter-digit delay over-engineering!
Regards, Fred
