SPA3000 Not Registering?
hectorahinojosa
I am setting up a voip system that will hopefully use the voip system to talk to each other and use a local pstn line to reach the outside world. The way I have everything installed is as follows.
SPA9000 Voip Server:
SPA941 IP Phone
SPA 3000 ATA Gateway for pstn line.
The problem is that though I can make voip calls between the phones setup for this I cannot get an outside dial tone from the SPA3000 or route external calls into the voip network. I have found no documentation clear enough for this configuration. Please help with details about pstn line bridge for incoming and outgoing calls.
The SPA3000 is not registering with the SPA900.
paolo bevilacqua
Wrong foru, post on "small business voice - SPA9000". You can move your post using the actions panel on the right.
