SPA303 phone key pad bleading over mic
jim.stansell1
Ever since my phone (SPA303) upgraded to software version 7.5.5 I have had an issue with the key pad bleeding over the mic while on speaker.
Example.
When I am on speaker and dial into a conference line that requires a pin, when I dial in pin (example) 12345  I get an error saying I dialed in 123345 or sometimes it is 1223445.  Seems the key tone is bleeding over the mic and the phone sends it as a dial tone for that key.  When I pickup the handset and dial in the pin, it works every time.
This happens on many different conf lines, not just one.  (GoToMeeting, WebX, Highdef Conf Calling)
Jaime Valencia
This is Video Over IP, please move to a relevant area.
java
if this helps, please rate
Moved to Telephony IP
