Hi all:
this is the fisrt time i have to extend a line with SPA3102 - SPA112, i have configured it and tested with a PSTN line and a local ethernet switch, i can make and recieve call. the problem starts when i connect the SPA3102 to a PBX, and the SPA112 is behind a wireless link i can recieve calls but not to make any call, SPA112 says Call state : invalid and Tone: Reorder under firmware 1.2, with the default firmware (1.9) Call tone was off-hook. SPA3102 have a line-in voltage: 28V. the wireless link is working as a WDS bridge, so mac addresses are passing as a normal ethernet switch.
any suggestions what can i check to solve this issue???
Thanks in advance!
