02-16-2014 05:08 AM - edited 03-21-2019 08:05 AM
Hello
Where can i get the firmware to upgrade Cisco SPA502G. Its showing "Initializing..." and when i talk to the dealer he as asked me to upgrade the firmware.
Thanks in advance.
01-22-2020 11:51 AM
i have to upgrade SPA502G the firmware of
but after processing at end it write upgrade failed i have disable firewall as well but still not able to upgrade it
01-22-2020 12:25 PM
Firmware version you are upgrading from ?
Firmware version you are upgrading to (filename) ?
01-22-2020 09:16 PM
01-22-2020 10:19 PM
right now my version is :
Software Version: 7.5.1a Hardware Version: 1.0.4
I want to upgrade it to :
SPA50X_SPA30X Firmware version 7.6.0
SPA30x_SPA50x_7.6.0_FW.zip
01-23-2020 02:08 AM - edited 01-23-2020 02:16 AM
Attempt to direct upgrade from 7.5.1a to 7.6.0 ?
You should read Release Notes before upgrade. All the times. The following sentence apply to you:
When you upgrade a Cisco SPA50X or Cisco SPA30X IP Phone, if you have installed a firmware version
prior to 7.5.2b, you must first upgrade to 7.5.2b before you upgrade to release 7.5.3 or a later release.
By the way, the following may be important for you as well:
This firmware release is only for the RC SKU. For non-RC SKUs, the firmware is the same as firmware
release 7.5.7s.
Are you sure the 7.6.0 is the version you wish to upgrade to ? The latest firmware so far is 7.6.2 SR6.
01-28-2020 09:10 AM
Thanks your guide helped me i have updated to
01-28-2020 01:44 PM
how can remvoe this provisioning ??
Reset to factory default.
01-28-2020 10:43 PM
01-28-2020 11:29 PM
Well - what's the doal ?
It's just log record about the phone restart (and the reason for it). It doesn't affect phone operation in any way.. Just restart has occurred in the past - and such event is logged
