01-24-2020 07:00 AM
Where can I get the firmware 7.5.5b for SPA525g? I could not find the versions older than 7.6.0.
Thanks.
Solved! Go to Solution.
01-24-2020 08:20 AM
Older firmwares are no longer supported. Call support if you can't use a supported version of firmware. May be they will provide you the older one.
01-24-2020 08:20 AM
