06-18-2012 04:06 AM - edited 03-21-2019 05:56 AM
Hi All,
I have a uc540 in my network. It was working perfectly then suddenly stopped working.
In a bid to solve the issue, I resetted the UC540 to factory default. I the tried configuring it
with the help of CCA.
The prob is that the SPA504and 7911 connected to it won't obtain IP Addresses from the UC540.
PCs connected to the UC540 do obtain IP Addresses.
Can someone help me out?
06-18-2012 01:28 PM
First of all check the dhcp configuration i.e network, Gw and tftp address.
Try with manual configuration of ip phone settings and static addresses.(if u have less phones)
Try restarting or resetting the phones, i faced a similar kind of issue with 7945 phones when reset them they started working fine. But first make sure you have the proper phone loads resetting some time gives issue with the phone loads and could be worse if phone unable to reach the tftp server.
Abdul Malik.
Pls rate the useful posts.
06-18-2012 04:35 PM
What do you mean suddenly stopped working? The UC540? Also what ports do you have the PCs in and what ports are the phones in? Is there other hardware in the equation?
