11-09-2015 11:47 AM - edited 03-21-2019 08:49 AM
I'm using 2 spa508g phones, in sip profile enabled unregistered make and receive calls.
I make a call to FreeSWITCH, which then bridges call to another phone (sip messages are going through freeswitch, rtp should go between phones directly).
Inbound call is received, and answered ok on freeswitch. Then OB call is made, 2nd phone is ringing. At this point everything still works as expected.
When I answer OB call on 2nd phone, freeSwitch send "UPDATE sip" to both phones.
At that point I receive "481 Call Leg/Transaction Does Not Exist" from Inbound phone; OB phone swallows that message without a problem.
I inspected SIP messages, all seems to be normal.
FreeSWITCH support people thinks the issue is with the phone (I'm pretty sure they've tested such scenario with other phones).
Note: spa508g phones runs on latest 7.6.1 firmware.
Log of the call is accessible @ https://pastebin.freeswitch.org/24444
User/password is in the auth window message.
11-09-2015 11:52 AM
SPA devices are supported in the SMB community, not here, you might want to move this.
11-09-2015 12:02 PM
11-09-2015 01:39 PM
Provide SIP packets catched here so we can analyze them.
11-09-2015 02:22 PM
I added link to log in the body of the post. Let me know if you'd prefer wireshark logs.
11-10-2015 04:07 AM
Wireshark logs are better, but we can try it even without it. Lets allow me to sumarise relevant parts of relevant packets. It's quoted on bottom.
I see nothing wrong with the UPDATE packet sent. Thus it may be firmware bug. In such case the SMB support center needs to be contacted. Cisco guys never accept bug reports here.
Setup of leg A (1038@spa->1039@FreeSwitch):
INVITE sip:5551234@192.168.182.11 SIP/2.0 From: "1038" <sip:1038@192.168.182.11>;tag=f8e5b064cf6e57f7o2 To: <sip:5551234@192.168.182.11> Call-ID: 82ef66a8-1c947683@192.168.182.38 CSeq: 101 INVITE Contact: "1038" <sip:1038@192.168.182.38:5060> User-Agent: Cisco/SPA508G-7.5.5 -------------------------------- SIP/2.0 200 OK From: "1038" <sip:1038@192.168.182.11>;tag=f8e5b064cf6e57f7o2 To: <sip:5551234@192.168.182.11>;tag=42Ke0y33FDjFm Call-ID: 82ef66a8-1c947683@192.168.182.38 CSeq: 101 INVITE Contact: <sip:5551234@192.168.182.11:5060;transport=udp> User-Agent: FreeSWITCH-mod_sofia/1.7.0-437-0d6e17b~64bit Remote-Party-ID: "5551234" <sip:5551234@192.168.182.11>;party=calling;privacy=off;screen=no
UPDATE (from FreeSwitch to 1038):
UPDATE sip:1038@192.168.182.38:5060 SIP/2.0 From: <sip:5551234@192.168.182.11>;tag=42Ke0y33FDjFm To: "1038" <sip:1038@192.168.182.11>;tag=f8e5b064cf6e57f7o2 Call-ID: 82ef66a8-1c947683@192.168.182.38 CSeq: 83001059 UPDATE Contact: <sip:5551234@192.168.182.11:5060;transport=udp> User-Agent: FreeSWITCH-mod_sofia/1.7.0-437-0d6e17b~64bit P-Asserted-Identity: "Outbound Call" <sip:1039@192.168.182.11> -------------------------------- SIP/2.0 481 Call Leg/Transaction Does Not Exist To: "1038" <sip:1038@192.168.182.11>;tag=f8e5b064cf6e57f7o2 From: <sip:5551234@192.168.182.11>;tag=42Ke0y33FDjFm Call-ID: 82ef66a8-1c947683@192.168.182.38 CSeq: 83001059 UPDATE Server: Cisco/SPA508G-7.5.5
