10-14-2015 05:59 AM - edited 03-21-2019 08:47 AM
I am trying to use our GIC service with SPA 525 phones and it looks like the phone is stripping the leading # off when I dial # and the GIC number. Has anyone else ran into this?
10-14-2015 12:53 PM
Feedback forum is dedicated to other topics. Moved to more appropriate community.
According the issue itself - we are not affected by such issue, we can dial numbers starting with # with no problem.
I assume you are using most recent firmware version on SPA525G2.
10-14-2015 12:58 PM
I am on 7.5.4
10-15-2015 10:55 AM
Well
it looks like
sounds so uncertain. Can you capture the SIP INVITE packed from the call setup ?
10-15-2015 11:51 AM
I will see what I can do. There is not an invite because it goes to fast busy. I have a C20 Genband switch and am doing what is called an A2 trace. I can see it in there that it is stripping it. But say I dial into a conferance and they need a # after code it works fine. I have about 500 phones that act the sameway all Cisco 525 and 514. If I use a polcom it works fine.
10-15-2015 11:57 AM
There are no packets or invite when I do this
10-15-2015 12:50 PM
Got it. I was using a dial plan that did not have the #XX in it. changed that and it is fine. But what is odd the Polycoms use the same dial plan and it works. Thanks for your help.
10-15-2015 05:13 PM
Glad to hear you solved it. Consider rating valuable advices, if there's one here.
Note you said "it looks like the phone is stripping the leading # off when I dial" thus I assumed the phone is dialing the number with leading # stripped.
There's nothing like "common description language for Dial Plan description". Thus Dial Plan on Polycom may have dissimilar meaning despite it look similar to Cisco's Dial Plan string.
