10-16-2015 03:08 AM - edited 03-21-2019 08:47 AM
Does anoyone aware which linux distribution/architecture is recomended by Cisco to run SPC compilers? I've some problems with newer version of spc binaries and looking for solution.
Piotr
Solved! Go to Solution.
10-16-2015 05:29 AM
Note the Cisco guys doesn't respond here. Call SMB support center if you wish for answer from Cisco guys.
Issues with linux binaries are recurring all the times I remember. Thus I advised you to avoid them and use XML format. It can be created, maintained and even encrypted (if you wish for encrypted configuration) by standard/native utilities available on Linux.
10-16-2015 05:29 AM
