SPA525G, 7-2-5 firmware issues
We noticed at customersite and in out lab that the SPA525G does not recognize distinctive calls. Phone like 7971/7940 network does recognize immediately the distinctive call. The 79series phones rings on a internal call and external call different. The SPA525G doesnot. Is there a reason for this behavior or is it a bug?
Secondly we notice when bluetooth is used with a Plantronics Voyager 510 headset that the callingparty noticed a high level of noise (irritating) in the connection. When connected to a cellphone the problem is not noticed. I have tested with a  Plantronics Discovery 925 headset a we noticed mutch less noise. Is there a reason for this behavior?
The UC520 systems running with 7.0.3 or 7.0.2 software.
Hi there,
I recreated the distinctive call issue and saw the same problem that you describe. Please open a TAC case so we can track this and file the bug, if required.
On the Plantronics headset question, did you check the compatibility information:
https://supportforums.cisco.com/docs/DOC-9926
Marcos
