Internal extension is set to Forward All Calls to cell phone (perhaps the critical piece of data).The call forwarding functions properly but the parties to the call can not hear each other.What, if anything, can be done to enhance the audio to a func...
Hi, http://www.cisco.com/en/US/products/ps10446/index.html The link to download software appears a little dead. I have also gone to the download section where I got firmware / template config for everything else and there is nothing for the 8800 only...
We have a client with 2 - 7960's for the 2 receptionists. About a month ago, the client had us modify the template and remove the DND softkey. However, after what appears to have been a power outage yesterday, once both phones came back up, they ar...
We have a uc500 base config is with 4FXO 4FXS portsWe need to use a PRI to use some of the UCC functions properly.I have installed the PRI card but when I login to the system tru the CLI it is asking me to install a licence file? Where would I get t...
I searched this site, UC500.com, and cisco for any installation guides setting up a Qwest PRI circuit on the UC500, and specifically on the VWIC2-1MFT-T1/E1=We're always doing Cbeyond SIP circuits and now we have a Qwest PRI circuit.Does anyone have ...
I have set the time correctly for CUE and in CCA all devices are synchronized but when messages are left in voice mail it has the wrong time. How do I fix this or even check it?Thanks
When I use the recomended procedure in the provisioning documentationprofile.xml<flat-profile><GPP_A> 123456</GPP_A></flat-profile>openssl enc –e –aes-256-cbc –k SecretPhrase1234 –in profile.xml –out profile.cfgand I and add the relevant key to my pr...
Using a UC500 with 7.0.2 package and upgraded IOS to 24T and have just updated the 7931 firmware to SCCP31.8.4.2S but the time is showing an hour behind all the other non-7931 phones and phone system.
We're newbies with Cisco and we have a big problem. Our password to access our UC520 no longer works. It did work yesterday. Is there any way to reset it back to the factory default?
Hello All,Can I get some clarification on ephone-dn's?I was under the impression that with software pack 7.1.1-EA, you could have multiple ephones with the same ephone-dn assigned to them. Not using shared lines but as their primary extension.I can s...
We have a UC500 that is located in the Moutain Time zone, but we have remote users all over the country in different time zones. How do you modify the phone system or the CIPC so that the correct time for that specific user's time zone is displayed...
Is it possible to setup one to one NAT translations on the UC? I have about 10 outside addresses that I need to translate to 10 inside addresses. I tried using CCA but it seems to only allow translation of type of services to addresses. is this poss...
Hello,My ATA worked fine, but now it seems that it entered an infinite Power cycle loop. The power LED change from red to green and then remain green for about 12 seconds. After that the LED is off and the cycle started again. During this period I ca...
