11-08-2012 05:12 AM - edited 03-21-2019 06:34 AM
Hi guys,
I have a SPA525G (Version: 7.5.3) which has no "Set Password" option under "Setup" -> "Device Administration".
it only has: Restart, Factory Reset, Call Control Settings.
do you have any ideas?
Thanks a lot.
Solved! Go to Solution.
11-08-2012 05:07 PM
Sounds like the phone was provisioned to block this access.
Are you able to get into the web UI of the phone?
Under System tab of web UI, is Phone UI user mode set to No? If so, set to Yes.
11-08-2012 05:07 PM
11-09-2012 12:11 AM
yes, the Phone UI user mode is set to No.
how can I set it to yes?
there is no drop menu..even if I go to http://IP/admin/advanced..
the "Web Server Writable" should be enabled.
Thanks.
11-09-2012 08:52 AM
If you are in the admin/advanced, you should be able to access all the settings. Are you able to see the drop down for other parameters? Just this one parameter has the drop down problem?
