10-30-2013 10:01 AM - edited 03-21-2019 07:53 AM
I'm using spa525g phones and I want to set the same configuration for all of them. I have my spacfg.xml standard file but I don't know how do I put it in the others telephones directory. I read something about provisioning section but I don't understand...
Can someone please help me?
Thank you
Solved! Go to Solution.
10-30-2013 12:24 PM
Save it to a tftp/ftp/http server then set "Profile Rule" configuration option to URL describing the configuration file.
Or use DHCP to set such URL.on all phones.
Note the security consequences - if the configuration contain some sensitive informations (like passwords) then it should not be downloadable by unauthorized persons.
10-30-2013 12:24 PM
10-31-2013 02:50 AM
thank you
