10-30-2013 08:47 PM - edited 03-21-2019 07:53 AM
Hi All,
I want to integrate my BE6K with CUCME,
my scenario below :
- HQ = BE6K (Medium Density)
- Branch1 = CUCME (2911)
- Branch2 = CUCME (2911)
- Branch3 = CUCME (2911)
- Branch4 = CUCME (2911)
Is there any portfolio sheet or document guide for this scenario?
Please advise,
Any input appreciated.
Ovindo
10-30-2013 10:26 PM
Hi Ovindo,
Just create a sip trunk on your cucm pointing to your each Branch CME routers.
(make sure the destination ip add. should be your cme voice interface ip) & create RG,RL,RP
as per your Branch DN's.
From CUCME to CUCM create voip dial-peer
dial-peer voice 10 voip
destination-pattern 3...
session protocol sipv2
session-target ipv4:''cucm ip-address"
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
voice-service voip
sip
bind control source-interface "voice vlan"
bind media source-interface "voice vlan"
10-30-2013 11:43 PM
Hi Amoduck,
Thanks for fast respons,
"Just create a sip trunk on your cucm pointing to your each Branch CME routers.
as per your Branch DN's."
please explain more about "create RG,RL,RP as per your branch DN's"
Ovindo
10-31-2013 01:30 AM
when you are creating sip trunks for different locations(Branch1,2,3..) you will need to point the proper trunk to be used. for that create a Route-group in which you will have your (sip trunk).Then Route-list.
Then create a Route-pattern (e.g 2XXX..CUCME side Extensions) and select appropriate Route-List.
AMOD
