SPA525G white screen since update to spa525g-7-5-4-bt.bin
propharmarenens
Today I updated my phone to the latest firmware (spa525g-7-5-4-bt.bin). After the reboot the phone displayed a blank white screen. The update process worked, I can access the web interface I can send and receive calls, the firmware on the phone is 7.5.4 but the screen remains white.
I tried to downgrade the phone to my initial firmware version (7.4.8) but the problem is the same. I tried to reset the phone to factory settings with no luck.
Hope someone could help me, an IP phone with an blank white screen isn't verty usefull.
Regards.
paolo bevilacqua
Wrong forum, post in "small business voice - Spa phones". You can move your post using the actions panel on the right.
paolo bevilacqua
propharmarenens
Thanks I moved the post.
Any idea for my problem ?
You not only moved the post, but marked it as answered in advance. You should not expect further responses ...
Nicolas,
if a firmware upgrade/downgrade and factory reset has not resolved the issue, it could be a hardware failure.
I assume the downgrade was successful,
the factory reset was successful,
and you can get to the web page of the phone,
but still no display, right?
Give a call in to the support center, 866-606-1866, and open a case, Describe the setps you've already taken.
if it's still under hardware warranty, should be no problem.
Dan
