11-05-2012 06:45 AM - edited 03-21-2019 06:32 AM
Hi guys,
I have a problem with a SPA525G.
The phone doesn't work over WLAN. it says it cannot associate with the AP.
The AP is a AIR-AP1041N-E-K9 (c1140-k9w7-tar.124-25d.JA1), configured with WPA2/PSK/AES.
The Laptops (Win/Mac) are working great but the phone doesn't associate. i've tried different auth types but no luck.
the configuration on the phone is pretty basic (SSID/WPA2/PSK/AES CCM/WLAN enable).
Do you have any ideas?
Thanks a lot.
11-05-2012 07:10 AM
Wrong forum, post in "small business - SPA phones". You can move your post using the actions panel on the right.
11-06-2012 02:51 AM
any ideas?
Thanks.
11-06-2012 05:38 AM
on the display comes: Failed to associate with SSID: [voip] keep trying in the background.
i've just run another test and it works with WPA/TKIP.
