08-12-2014 01:24 PM - edited 03-21-2019 08:20 AM
Hi!
I have some ip phones spa525g2. Today, almost of all phones were upgraded by me, besides one phone. At this phone installed firmware version 7.4.8. I want to upgrade to version 7.5.6. When i try to upgrade it on web interface i have an error like "CRC error". Ok. Then i try to install version 7.5.1a, but i had same result. What should i do in this situation?
P.S.: Sorry for my English :)
Solved! Go to Solution.
08-12-2014 07:10 PM
Upgrade to 7.5.2b then upgrade to 7.5.6
Note: Bug in the latest spa3XX-5XXG phone firmware 7.5.6 - Can not transfer anonymous calls
Mark response as "answer" if it solve your problem. It will help others to found solutions.
08-12-2014 07:10 PM
08-12-2014 09:44 PM
Thank you! Your advise was useful. But i didn't find 7.5.2b. I found 7.5.2a.
08-13-2014 01:36 AM
Despite usefull, my advice has been wrong. Intermediate 7.5.2b is required on SPA50xG class of phones, not on SPA525G2 as I misclaimed.
So lets start from scratch.
Is it possible to upgrade the device to any new firmware, for example 7.4.9, or it's not posible to upgrade it at all ?
In the second case, try reset to factory default then repeat. If still not work, it may be unit with damaged flash inside. Turn on syslog&debug messages and catch them - it may reveal more about the issue.
