Spa5xx phones does not update timezone via xml files- firmware 7.4.9a
rallie
I am unable to update the time zone uisng a xml file that is downloaded from the Broadsoft  platform. When   When i extract the SPACFG.xml file from the phone the timezone field displays thsi error:  "<Time_Zone group="Regional/Miscellaneous">[LABEL NOT FOUND]</Time_Zone>.
Attached is the SPACFG.xm  phone configuration file and the   509system.xml that the phone downloads form the server during auto configuration process.
nseto
Level 6
Level 6
I'm running 7.5.1a and my xml file pulled from the unit does show GMT -8.00 which matches what is seen the web UI.
What do you see in the web UI for this parameter?
Can be a notation error in your xml. Try to change this:
  GMT+02:00
  GMT+02:00
with:
  GMT+02:00
Regards.
