SPA5XX proxy limit
echan
What is the limit on the number of proxies servers that can be designated in the “Proxy:” field?
CTRLITINC
Eddie,
This is done using DNS using either SVR or A record as follows:
For SRV Record:
sip.server.com:SRV=node1.sip.server.com:5060:p=1:w=5
0|node2.sip.server.com:5060:p=2:w=50
NOTE Set "Use DNS SRV" to no and "DNS SRV Auto
Prefix" to no.
For A Record:
sip.server.com:A=172.20.2.1,172.20.2.2
Prefix" to no.
Creating these DNS records will enable you to in effect have numtiple SIP Proxy.
Please consult the Admin Guide where it explains this in more detail:
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/spa500_admin.pdf
Check the following pages:
Page 89   - SIP Redundancy
Page 107 - Configuring a SIP Proxy
HTH,
Steve Wofford
Call Ctrl Call Manager for
SPA900 - SPA500 IP Phones
The question is whether there is a limit to the number of servers that can be defined.
There was none stated w/in the docs, so your guess is as good as any, unless you find someone who has came upon this limit through testing.
