SPA8000 configuration backup?
hennigan
We are evaluating the Cisco SPA8000 for deployment.  I have configured a unit via its web GUI and have it working as desired.
I have searched available documentation and also searched the web without results.
How does one back up the configuration of this device?  I want to extract the present configuration in order to have it on file should hardware replacement be necessary or as a basic template for scripting changes to deploy multiple units.
Ideally a human-readable text file or XML would be good but even a binary would suffice for hardware replacement purposes.  It's obviously possible to import a new configuration to a device but how do I export an existing known working configuration from one?
7 Replies 7
These are instructions from DOC-9905:
There are two distinct sections that must be saved separately, namely the Network tab and the Voice tab.
A. Saving the Network configuration of the SPA8000:
1. Direct your browser to http:///admin/advanced
2. Use your browser's save page feature to write the device's entire Network configuration to a single file:
IE: Page > Save As > Save as type Webpage, HTML only
FireFox: File > Save Page As > Save as type Web Page, complete
3. Name the file as follows: SPA8000-Network_date_time.html
Example: SPA8000-Network_Sep082009_06h44.html
B. Saving the Voice configuration of the SPA8000:
1. Direct your browser to http:///admin/voice/advanced
2. Use your browser's save page feature to write the device's entire Voice configuration to a single file:
3. Name the file as follows: SPA8000-Voice_date_time.html
Example: SPA8000-Voice_Sep082009_06h44.html
If you want an XML file, type in the following command which will show the configuration in an xml format:
http:///admin/config.xml
If it doesn't work you must download the SPC tool and generate an xml file. This file has all default values. You must change every values manually.
Regards.
Well, simply capturing the HTML of the GUI isn't really very useful.  It's a pain to parse and virtually useless for any kind of automated restoration.
Your suggestion:
would be fabulous if it worked.  It does not.  It returns 404 not found.
Some digging around found this, for anyone else who is looking:
http:///spacfg.xml
This works!!!  :-)
Hi. How do I used this .cfg file for back on a new decicd if need. Is there away to upload it to apply all the configurations?
Configuration can't be uploaded to phone via UI from browser.
spacfg.xml is configuration file suitable for provisioning (beware - it contain no passwords). Read Administrators guide to learn more about provisioning process.
hennigan
The command is:
http:///spacfg.xml
to return the configuration in XML.  Passwords are masked.
Hhhm either this http:///admin/config.xml or this http:///spacfg.xml
doesnt work for me
Just the IP address, able to access the device.
Firmware 51.1.10
You should use the full URL.  for example: http://10.16.2.154/admin/spacfg.xml
