SPA8000 daylight settings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-26-2012 11:01 PM - edited 03-21-2019 09:42 AM
I'm having issue with SPA8000 daylight settings
eg
using this parameters for NSW timezone (used in other SPA units eg SPA900, 500 series etc)
<Time_Zone ua="na">GMT+10:00</Time_Zone>
<Daylight_Saving_Time_Enable ua="na">Yes</Daylight_Saving_Time_Enable>
<Daylight_Saving_Time_Rule ua="na">start=10/1/7/2;end=4/1/7/3;save=1</Daylight_Saving_Time_Rule>
it doesnt seem to work on this SPA8000 as its not showing the correct time.
Software Version: | 6.1.10(001) | Hardware Version: | 1.0.0 |
Any thoughts ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-03-2012 02:19 PM
Try the following, exchange the start and end dates and use save=-1 instead. The result should work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-26-2012 09:30 PM
Hi nseto,
Thank you for your response. We have tried entering the Time Rule as start=4/1/7/3;end=10/1/7/2;save=-1 however we are still unable to display the correct time on the device.
Example of what we see
Actual current date/time:
2/27/2012 16:28:09
Displayed date/time on SPA8000:
2/28/2012 15:53:09
Do you have any further suggestions that we can try?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-28-2012 09:03 AM
The rule shouldn't take effect since it's set for april to october. Time shown should be actual, what are you using for the time server? We recommend populating the Primary NTP Server parameter with a well known ntp server such as pool.ntp.org. Also, make sure the Time Zone parameter is setup to the correct GMT offset for your region.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-29-2012 09:58 PM
Hi nseto,
The SPA8000 is now able to retrieve the correct timezone settings (just took a while to update off the NTP). Thank you for your help.
