Showing results forĀ
Search instead forĀ
Did you mean:Ā
SPA8000 didn= ???
Peter Flaherty
Is there a way to pass a didn=xxx reference into an SPA8000 (similar to the SPA9000) to select a specific ATA channel on the device ?
On the SPA9000 if you pass in an addidional SIP parameter eg  "x-To: dnid=xx" your inbound will get routed to xx
Just looking for similar functionality, so you could use a single trunk, and route an inbound call to a specific port on the 8000
0 Replies 0
