Showing results forĀ
Search instead forĀ
Did you mean:Ā
PAP2 keeps rebooting with reboot reason:H736c0041
kralg0000
Hi!
We had been running a PAP2-NA unit without problems for quite a while. Last week it started rebooting after every 5-6 seconds and keeps logging the followings:
Jan  1 12:00:00 001217FD2269 System started: ip@192.168.6.5, reboot reason:H736c0041
Jan  1 12:00:00 001217FD2269 #011subnet mask:#011255.255.255.0
Jan  1 12:00:00 001217FD2269 #011gateway ip:#011192.168.6.1
Jan  1 12:00:00 001217FD2269 #011dns servers:#011
Jan  1 12:00:00 001217FD2269 192.168.6.1
Jan  1 12:00:00 001217FD2269 Line 1 Proxy:sip.neophonex.hu
Jan  1 12:00:00 001217FD2269 Line 1 Outbound Proxy:sip.neophonex.hu
Jan  1 12:00:00 001217FD2269 Line 2 Proxy:sip.neophonex.hu
Jan  1 12:00:00 001217FD2269 Line 2 Outbound Proxy:
Jan  1 12:00:00 001217FD2269 Profile Rule:/init.cfg
Jan  1 12:00:00 001217FD2269 Profile Rule B:
Jan  1 12:00:00 001217FD2269 Profile Rule C:
Jan  1 12:00:00 001217FD2269 Profile Rule D:
Jan  1 12:00:00 001217FD2269 Line 1 Preferred Codec:G711u
Jan  1 12:00:00 001217FD2269 Line 2 Preferred Codec:G711u
Jan  1 12:00:00 001217FD2269 RTP Packet Size:0.030
Jan  1 12:00:00 001217FD2269 IDBG: st-0
Feb 16 01:14:38 001217FD2269 RSE_DEBUG: reference domain:sip.neophonex.hu
Feb 16 01:14:38 001217FD2269 DNS Querying host: sip.neophonex.hu, result ttl=318
Feb 16 01:14:38 001217FD2269  Query result ip[0]:193.91.75.213,
Feb 16 01:14:38 001217FD2269 [0]RegOK. NextReg in 3599 (1)
Feb 16 01:14:38 001217FD2269 [1]RegOK. NextReg in 3599 (1)
Feb 16 01:14:39 001217FD2269 fs: 09483:09483:65536
Feb 16 01:14:39 001217FD2269 fbr: 0:0000:0000:02e0e:0004:0003:3.1.3(LS)
Feb 16 01:14:39 001217FD2269 fhs: 01:0:0001:fp2:rd_pval:6:-1:0
Feb 16 01:14:39 001217FD2269 fhs: 02:0:0002:upg:app:0:3.1.3(LS)
Feb 16 01:14:39 001217FD2269 fhs: 03:0:0003:upg:app:1:3.1.3(LS)
Feb 16 01:14:39 001217FD2269 fhs: 04:0:0004:upg:app:2:3.1.3(LS)
Does anyone have any idea what reboot reason H736c0041 is?
It looks to me that it even connects successfully, but after a second it spuriously reboots...
Software version: 3.1.3(LS) Hardware version: 0.03.4
Any clues are welcome!
This is my suggestion:
"H" reason normally means an hardware reboot, usually caused by power or code reset.
Try to upgrade your PAP with the last firmware 5.1.6, perform a factory reset and reconfigure it.
You can download the firmware from this link:
http://www.cisco.com/cisco/software/release.html?mdfid=282414114&softwareid=282463187&release=5.1.6&relind=AVAILABLE&rellifecycle=&reltype=latest
If the problem is not fixed, check your warranty and open an RMA.
Regards.
Hi Daniele,
Thanks for your response. I tried upgrading the firmware but it doesn't start downloading the new one, I guess because it never gets into idle state. As I mentioned it restarts every like 8-10 seconds.
Any idea how to figure out the meaning of this reason code?
Thanks.
I've noticed that the PAP reboots continuously if the "Internet" port is not connected. Try checking the cable and try connecting the PAP to a different device.
Regards.
