01-02-2013 08:39 AM - edited 03-21-2019 06:47 AM
Hi good morning
Can I use 2 or 3 SPA8000 to get analog extensions with a UC560?
We need to connect 20 extensions ..
regards
Solved! Go to Solution.
01-02-2013 12:13 PM
No, the only supported methods for FXS are:
1. Built-in FXS Ports
2. VWIC FXS card
3. SPA8800
(Officially anyway... if you are configuring in CLI... the VG224 *might* work -- in fact it almost certainly would in H323 mode... SCCP is a bit more iffy)
01-02-2013 10:04 AM
If you need to connect 20 extensions the best option would be a VG224 (24 ports). SPA8000 would work but please note that testing (and support) has covered only 1 SPA8000 per system.
01-02-2013 10:57 AM
You... answered yourself? 0_o
01-02-2013 12:11 PM
Hi Daniel,
No, someone already answer to me what you see above, I wanted to share it with the community, however I have another question
Does the UC560 supports the VG224?
01-02-2013 12:13 PM
2. VWIC FXS card
3. SPA8800
01-02-2013 12:17 PM
Thanks Daniel
