SPA922 and PPPoE
Tomas Chott
Hello !
Today i trying use SPA922 in PPPoE mode.
Phone is connected to LAN with DHCP server, if i set DHCP all works fine, if i set PPPoE with login and password phone cannot get IP and cannot connect to PPPoE.
I trying connect PC and PC works fine with this settings.
Maybe phone doestn work in this mode :-)
Thanx
Tomas
Alberto Montilla
Hi Tomas;
Make sure you do to things:
(1) On the phone display change the connectivity method from DHCP to PPPOE and save the change
(2) Reboot the phone...
It should work properly, this is a tested configuration.
Regards;
Alberto
