11-06-2013 06:14 AM - edited 03-21-2019 07:54 AM
Cisco 881 Router config:
ip dhcp excluded-address 10.1.0.129 10.1.0.130
ip dhcp pool PHONES
network 10.1.0.128 255.255.255.192
domain-name blabla.com
dns-server 10.0.2.11 10.0.2.24
default-router 10.1.0.129
option 42 ip 10.0.2.29 10.0.2.35
option 150 ip 10.1.0.3
option 66 ascii 10.1.0.3
lease 31
I have linksys spa922 phone with firmware 6.1.5(a) and some spa303, spa502..
All the devices understand tftp options from dhcp server, but spa-922 not.
I have log on debug server:
Nov 6 09:03:09 10.1.0.131 System started: ip@10.1.0.131, reboot reason:H0
Nov 6 09:03:09 10.1.0.131 subnet mask: 255.255.255.192
Nov 6 09:03:09 10.1.0.131 gateway ip: 10.1.0.129
Nov 6 09:03:09 10.1.0.131 dns servers(2):
Nov 6 09:03:09 10.1.0.131 10.0.2.11
Nov 6 09:03:09 10.1.0.131 10.0.2.24
Nov 6 09:03:10 10.1.0.131 IDBG: st-0
Nov 6 09:03:10 10.1.0.131 src/dict_tftp.c: dictParseServerScp: 1501 script too short
Nov 6 09:03:10 10.1.0.131 ---------- g_dict_enable[0]: 0, : -2621441
Nov 6 09:03:10 10.1.0.131 syslog-ng[1328]: Error processing log message: <Embedded Msg>: save param: 441 = 255 441
Nov 6 09:03:10 10.1.0.131 DDE12 0 0
Nov 6 09:03:10 10.1.0.131 dictTftpNum: 0
Nov 6 09:03:10 10.1.0.131 paylen: 0
Nov 6 09:03:10 10.1.0.131 Dict_N> Dict flash[1] err happened, check errcode1=1
Nov 6 09:03:10 10.1.0.131 DICT_verify: 1
Nov 6 09:03:10 10.1.0.131 Dict_N> Dict flash[1] err happened, check errcode2=1
Nov 6 09:03:10 10.1.0.131 Dict_N> Dict flash[0] err happened, check errcode1=1
Nov 6 09:03:10 10.1.0.131 Dict_N> Dict flash[0] err happened, check errcode2=1
Nov 6 09:03:10 10.1.0.131 3.0 deadbeef 48879
Nov 6 09:03:10 10.1.0.131 DDE11 0 0
Nov 6 09:03:10 10.1.0.131 DDE13 0 0
Nov 6 09:03:10 10.1.0.131 [SCAPS]WaitTime:10
Nov 6 09:03:11 10.1.0.131 [SCAPS]WaitTime:20
Nov 6 09:03:12 10.1.0.131 [SCAPS]WaitTime:40
Nov 6 09:03:14 10.1.0.131 [SCAPS]WaitTime:80
Nov 6 09:03:14 10.1.0.131 Resolving 10.1.0.3
What is the reason that the device does not accept dhcp option correctly?
11-06-2013 10:19 AM
It is possible that SPA922 is using other option than SPA303. So at the first, you must found what option is triggering
error. Use option 150 but not option 66 and vice versa. It should reveal what option will cause the error.
Also, you should catch the DHCP server's response packet. It's nice to know Cisco 881's configuration, but the bug may be in Cisco 881 itself. If it's response is malformed (in option used by SPA922 but ignored by SPA303, or SPA303 may be more resistent to bug than SPA922) then it's waste of time to play with SPA922's configuration.
