space flash
rchakchouk
Beginner
Beginner
hello,
how can i make a space in the flash ? thanks
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Delete useless files.
David Trad
Rising star
Rising star
Hi Raghda,
You can use CCA to inspect the files on your flash card and remove them, in particular you should look at phone loads and remove ones that you will not be using or are loaded on the system and you do not use those phones.
Then look for any crashdump files as sometimes they can get large in size, and then finally check and make sure you do not have multiple IOS's stored on the card. Typically when using CCA to update a system you would get it to also format the flash card and reorganize it for you so that way everything is within a structured folder system.
If using CCA is not possible then you can remove the card and use a compact flash card reader and do it manually that way, however please be mindful that in doing so you will loose Music On Hold for the duration of the card being out of the system.
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) **
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Recognize Your Peers
