Hi,I want to upgrade my SPA112The manual says to click on administration and then upgrade firmware.In my administration I have only have "quick setup" Don't have firmware upgrade.any idea?thanks,JH
Greetings,We have signed up for SIP trunking with Engin. They provided us with 4 channels and 10 DID's. The first DID we configured to a Blast group and this works fine. The remainder to different extensions, this does not work. All numbers d...
Having a very strange issue with UC560. This is a brand new box with default factory configuration. I was trying to log onto to CCA, but I kept getting error message saying failed to authentication using TELNET. Telnet access is required for access t...
Hi All,I've recentlty purchased a Cisco Spa112 to replace an old Grandstream adaptor.I do not have dial tone on device.I tried to dial **** but no voice prompt.I am using the device to set up a remote phone line with home country.The device was remot...
Out of the blue, I came to my office and all phone calls are ringing extension 100. No auto attended is even being engaged. Same applies to Fax Line.. any clues?
Cisco clearly says BE3K does not support SRST. Just making sure, if you add a 2900 router with PRI, would it then be able to do SRST with BE3K?Also, how many FXO's will BE3K support, and how? VG224 is only FXS, correct? SPA8800 supports 4 FXS, 4 FX...
I'm having problem to access to a call blast voicemail, this group has two member, when I try to access through the phone, I need a password, in the CCA there's no way to setup this, so I go to the CUE using the web interface, and I can't find where ...
Hi, I wonder if anyone can help me or point me in the right direction for a hardware question? A few years ago I bought a couple of Cisco IP phones (SPA502G) and they have been brilliant, however I spilled water onto the base of one of them and the...
Hi guysCan someone confirm if the SPA500DS working on the UC560? I upgrade my SPA500DS hopefully waiting it works with the UC560. Does someone Know something about it or haveany document that could help ?Thanks!!
Hello all, Here I am with another "fun" question about the UC Ok so for the last few days, I have been working on a client's UC560 so that we have different queues for french and english callers.For most of the setup, I have been able to provide the ...
Hello Community.Is it possible to disable the phonenumber logging by the UC. I like to create a prefix for example a prefix "10" and the phonenumer that is entered after the prefix will not be logged by the UC. So an UC Administrator doesn't see whic...
Hi, I recently installed two Cisco 7965 IP phones in a infrastructure with a UC560. The phones work fine, however I'm unable to configure device settings. I'm can only alter some user settings (ringtone, background) directly on the phone. I'd like to...
Hi have setup a virgin UC560 via the wizard and mapped in-dials to extensions PRI port.Once the config is finished under the users/phones phone extension the DID doesnt map in the edit phone/button window. (although diagnostics call routing does rout...
