11-30-2010 06:15 PM - edited 03-21-2019 03:19 AM
Hello All
I am using SPA508 with SP500s expansion module (On UC540). I can create speed dial (to External number 9.XXX XXXX) but I want to assign this to one of the Line button on Expansion Module. I am using CCA 2.5 and could not get an option.
Secondly If I want to dial this SD how could I do that...
Hope this is clear..
Rana
12-01-2010 02:31 AM
What kind of speed dial do you want?
We have System speed dial, where you administer a common set of speed dials for every phone.
We have local speed dial (CCA calls this personal speed dial), where you can assign specific numbers to each phone individually.
We have abbreviated dial speed dial, which you can administer from the phone.
Often a confusing topic, since the IP Phone is very powerful here, and the options exist. Also because we don't explicitly map speed dials to buttons. If there are unassigned buttons, speed dials will fill them in (local speed dials that is), but not hard assigned.
Need more detail?
12-01-2010 05:48 AM
Thanx a lot
12-01-2010 03:06 PM
I thought this may help you, since I typed my last answer from my iphone...this is better I think?
Feature/ Function | Category | Description | CCA: Wizard | CCA: Expert Mode | Office Manager | Phone TUI | Operate Notes |
Personal Speed Dial from Directory | Dial Plan | With this feature, you can configure a maximum of 24 personal speed-dial numbers per phone; the numbers are accessed through the Directory, Personal Speed Dial listing. | Phone System> Phone Menus | CME Services> My Phone Apps> Personal Speed Dial | Directories> Personal Speed Dial : Select and dial |
Speed Dial Buttons with Abbreviated Dial | Dial Plan | This feature allows you to quickly dial a phone number by entering an assigned index code (1-99) on the phone keypad. Up to 55 supported from CCA, all or additional 44 from phone TUI. Abbreviated dialing SoftKey is used to dial these numbers or the button on the phone as these will occupy unassigned phone buttons. | Configure> Telephony> Voice Features> Speed Dial | CME Services> My Phone Apps> Speed Dial Buttons | Press index (1-99), then AbbrDial Softkey |
System Speed Dial from Directory | Dial Plan | Configured by the administrator and is shared between all IP phones on the system. You can configure personal speed dials and speed-dial buttons on your individual IP phones. Implemented via Speeddial.xml file on flash: | Configure> Telephony> Voice Features> System Speed Dial | Directories> Local Speed Dial: Select and Dial |
12-12-2010 05:50 PM
But on 8.0.2 SP, you can only use Abbrev Dial on the first
20 "Speed Dial Buttons with Abbreviated Dial"
