SR520 FE Teleworket, connect to UC560
graeme
Hi There,
We have a SR520 Teleworker solution, from a UC560 setup as per Cisco Documentation and was working fully. Main site can ping remote site, and vce versa.
Now as of this morning for some reason when you ping the main site4 from remote site it works, but from the main site it fails.
The SR520 WAN IP is 192.168.16.2 (its behind a router) and LAN IP is 192.168.75.1
If you ping 192.168.75.14 Tracert shows the packets going to the UC560 for routing, then the next hop is 192.168.16.2 of the SR520, not the LAN IP. then no response
If you tracert to 192.168.75.1 it goes UC560, then 192.168.75.1 and ends as its succesfuil
So for some reason the UC560 is routing to the WAN IP of the SR not the LAN IP.
Any suggestions as to a possible fix?
Graeme
graeme
Any one got any siggestions on this?
Please?
