T.37 Faxing with UC560
HEATH FREEL
I have configured this and appear to be running into a Dial-Peer issue in that I am not matching on the outgoing dial peer. This is a lab configuration and here are the applicable Config entries.
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server 172.21.12.12 port 25
mta send subject FAX
mta send postmaster myemailaddress
mta send mail-from hostname sendingaddress
mta send mail-from username $s$
application
service onramp flash:/app_faxmail_onramp.2.0.1.3.tcl
service fax_detect flash:app_fax_detect.2.1.2.2.tcl
voice-port 0/1/1
dial-peer voice 233 pots
service onramp
incoming called-number 5551212
direct-inward-dial
port 0/1/1
dial-peer voice 232 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 5551212
information-type fax
session target mailto:myemailaddress
image encoding MH
image resolution fine
dsn failure
I am matching on the incoming - but I thought it should then send it to the next dial peer - but I get no match.
Dec 15 21:53:05.512: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
  Calling Number=, Called Number=, Voice-Interface=0x87D74004,
  Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
  Peer Info Type=DIALPEER_INFO_SPEECH
  Match Rule=DP_MATCH_PORT;
  Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=233
Dec 15 21:53:05.512: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
  dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Dec 15 21:53:05.512: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6475
Dec 15 21:53:05.516: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
  Calling Number=, Called Number=, Peer Info Type=DIALPEER_INFO_SPEECH
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Dec 15 21:53:05.516: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
  dialstring=, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
Dec 15 21:53:05.516: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
  Result=NO_MATCH(-1)
Any help is greatly appeciated.
Heath
I'm not sure, but try to add this translation rule. The goal is add a called number in incoming calls from FXO port.
If it doesn't work, add the output of debug voice ccapi inout.
voice translation-rule 10
rule 1 /.*/ /5551212/
voice translation-profile ADD_CALLED
translate called 10
voice-port 0/1/1
translation-profile incoming ADD_CALLED
Regards.
9 Replies 9
eric.ahernandez
Have you tried doing the configuration with the Cisco Configuration Assistant? I did a deployment for a T.37 fax onramp using the CCA version 3.1, the configuration is really easy and it works, at least for me it worked on the first try, so I really advise you to try it.
No we do not generally use the Configuration Assistant as we do everything in CLI for customer Deployments. Would you be able to share the Dial-Peers that were created in the CLI for the t.37 config?
Heath
In your call the Calling and Called number are missing:
so, your router can match only the physical port:
so, the matched dial-peer is the pots dial-peer 233.
Is the voice port 0/1/1 an analog FXS port? Can support DID?
Regards.
It is an Analog FXO and therefore does not display Calling or Called Identifiers. That is why I used the Port 0/1/1 for matching the incoming peer - but how to I get it to then match on the MMOIP dial-peer.
translate called 10
voice-port 0/1/1
Regards.
Daniele, That made a huge difference - answers and I heard fax tones... Now I need to trouble shoot the mail part as I got this...
Dec 16 19:46:33.211: %MSPI-4-MSPI_NO_SMTP_SEND: MSPI- Could not
send data to the SMTP server, cid=163, mspi_on_xmit, lost connection
Thanks a bunch for your help.....
Now you can use the command debug mta send all. Post the output.
Regards.
Thanks again,  great help... I was able to get it going....
Hi Heath,
this are the only ones I found that are related to the T.37 fax-to-mail config:
dial-peer voice 1800 mmoip
description ** fax onramp for outbound faxmail to CUE **
destination-pattern ^....$
session target mailto:$d$@10.1.10.1
dial-peer voice 3028 pots
service cca_fax_detection
incoming called-number .%
direct-inward-dial
port 0/3/0:0
dial-peer voice 3034 pots
description FAX_T37
translation-profile incoming FAX_T37_Called_36
service cca_onramp
incoming called-number 2469
direct-inward-dial
port 0/3/0:0
This last one is because I have it configured with a DID... don't ask me about the destination patterns because I really have no clue... cca does some crazy stuff.
