I think I need transcoding and/or mtp resources for some VoIP/SIP to ISDN calls that are experiencing no audio in either direction
Anyone have a configuration for me to apply? Don't see a way to do it via CCA 3 -
Only DSP configuration I see comes via hardware conference bridge which I setup already
And my T1 PRI
I'm not even sure this is my problem but I don't see what else it could be
It's a site to site VPN tunnel with SIP / VOIP dial peers - and calls to local CME ip phones work fine - audio bothways is good
Only when caller sends me 10 digits over this same VoIP trunk / VPN tunnel for local call to send out my ISDN PRI T1 do I get no audio both ways
Call drops / disco's at about 20 seconds with some sort of timer expiry cause in debugs
Thanks in advance
MG
