04-26-2011 12:18 AM - edited 03-21-2019 03:59 AM
Any support for VLAN configurations ? A device has multiple VLANS, how will this appear ?
Specifically any support yet for UC320 ? Voice VLANs on 'other' side of the device ?
or another example SA540 with WIFI and multiple VLANS ?
Solved! Go to Solution.
04-26-2011 07:09 AM
You have to connect the appliance to the ESW in this version. In the new UI, operations with supported Cisco devices will not depend on the success or failure of the discovery process, since you will have the ability to "declare" a device that has just been found by IP.
Marcos
04-26-2011 06:40 AM
UC300 is not supported on the Portal version that is available to Trial users now. When we release the new UI, you will see UC300 supported there. If you provide credentials to the UC300, the Thunderbolt device will discover phones sitting on the voice VLAN.
Marcos
04-26-2011 06:49 AM
I knew UC 300 was coming later, but I have the credentials in place - from what I can tell. But no phones are discovered off the UC300. These devices are on the voice vlan, but physically connected to an ESW 540-8. I have a MAC connected to a phone and it is discovered and placed off the ESW (data vlan)
04-26-2011 07:09 AM
Marcos
04-26-2011 07:39 AM
Thought that might be the case as I looked at supported device list.
Ok. Will try it.
