12-04-2011 05:28 AM - edited 03-21-2019 05:02 AM
Hello there,
Just trying out the UC320 I got borrowed from Cisco AT for testing with firmware 2.1.2 (1) localized for Austria.
The device is connected to the cable modem of my ISP (Kabelsignal) utilizing two FXO ports, getting an IP address from my DHCP being connected to a WS-C2960G-24TD (LAN 1@UC320 connected to Gi0/18@C2960G port macro Cisco Switch enabled).
Now I would like to try/see the following features:
- a correct time and date: huh? hwo/where???
No option to set this right??? No NTP option??? Am I just blind or too stupid to find that option/s?
- upload own messages for the AA: ok, there are german messages but someone might have a little bit personalized ones - maybe telling callers the company name before asking them to dial the extension if they know it. Making custom messages is not the problem - but how to upload and in which sound/data format?
- caller ID: my ISP told me that he transfers the caller ID correctly to analoge end devices if caller ID is available and not suppressed. All I can see when a call comes in is which FXO Port is being used by that call. So callback entries on the SPA phone is senseless. Any advise?
- CLI: You can telnet the device - but which credentials to use to successfully logon? The pre-assigned credentials form Cisco AT are not accepted for logon.
BTW @cisco guys: I am also voting for support for the older SPAs (e.g. 942)
12-05-2011 07:43 AM
Hi Claus,
Thanks for giving the UC320W a spin and glad you found the support community! Let met see if I can help answer your questions....
Cheers,
Chris
07-09-2013 09:35 AM
Hello, has anyone updated this MOH limit and/or uploading a custom Mp3 to the UC320?
This last response is 4 years ago!!
Thank you, Paul
08-23-2013 08:36 AM
+1
