UC320 Outgoing Caller ID
digitalchild
Hey everyone,
I've been digging around the UC320 config and the SPA504g settings to try and work out a way to block outgoing caller ID on all but the FXO1 or all fxo's right now all would work.
I can't find anything in the config to do that, but I have found the setting on the SPA504G however it is set to NO and I can't edit the setting.
Am I missing something?
cheers,
Hi Jamie,
Outbound caller ID on FXO circuits are controled by your FXO Service Provider.  You will need to contact them.
Chris
