02-06-2014 09:17 AM - edited 03-21-2019 08:03 AM
System has been install for a couple of years. Recently Several users are attempting to change their voice mail greeting. User goes through the process, saves changes. They then go ahead and call to test. The greeting has not changed to new one. Issue is across two types of phones. total of 7 users, only 3 are having this issue.
Any ideas will be greatly appreciated.
Tom Knapp
02-07-2014 04:40 AM
Did you upgrade your firmware recently ?What is the firmware you are currently using?Also let me now the type of phones in which you see the issue?
Deepika
02-07-2014 11:05 AM
THank you for the response: No firmware updates. Firmware is 2.2.2.1. Two types of phones SPA509G and SPA525G.
02-10-2014 03:25 AM
Tom,
Voicemail greetings for both busy and unavailable can be changed easily in the SPA509G and SPA525G, but the fact is
unavailable message is played instead of the busy message ,when the line is completely occupied.
Its a know limitation in UC320
Deepika
