UC320W as voice only appliance
jyoopro4ia
How does one configure the UC320W to only work as a voice appliance?
I'd like to have a separate firewall (ASA5505) terminating WAN and a POE switch (any recommended model?).
Since the box services both data & voice vlan, do we need setup a trunk port to another switch? (is the UC320W capable of this?)
Any input will be appreciated.  TY
J
juliomar
Level 3
Level 3
Hi J,
Yes you can use the UC320W to work as routing Voice only.  You can set the ASA to route Data to WAN.  We have a Smart Design that entails the scenario that you are attempting- though it describes using the SA500, you can use the guidelines to setup using your ASA.
Here is link to UC320W documentation.
https://supportforums.cisco.com/docs/DOC-14783#Smart_Designs_and_Application_Notes
Near the bottom is the document that will guide you with your deployment:
http://tools.cisco.com/s2slv2/ViewDocument?docName=EXT-AS-370391
As for a POE switch, take a look at the Cisco SG300.
Hope this helps you move on right direction.
Best regards,
Julio
juliomar
Level 3
Level 3
Hi J,
Best regards,
Julio
Julio thanks for the docs.  I will take a look at them.
J
