UC320W Dropped calls (Inbound Only)
marvinfonacier
Hi Guys,
We are encountering several issues with incoming calls. We see the caller ID fromt the phone but when a user picks it up, the call gets disconnected. It is very intermittent and it doesn't happen in every call. Like 2-3 calls every 1.5 hour.
Cisco UC320W
Firmware: 2.1.2(1)
Phone Qty: 6
Topology: UC320W Routes Voice and Data
Any insights?
Thanks in advance,
Marvin
marvinfonacier@yahoo.com
5 Replies 5
Hi Marvin,
Is the system using SIP trunks or FXO trunks?  In either case, log into the UC320W Configuration Utility go to Status -> Support Tools -> Log and enable logs for your trunks.  Ask the end users to notify you when a call fails noting the time and what they can remember from the phone number at that time.
The logs may give you a clue what is going on.  If you need help interpreting the SIP messaging, you will need to contact the Cisco Small Business Support Center.
Cheers,
Chris
Thanks Chris. I actually just enabled SysLog and waiting for the end user to report the time and phone number(s) of any incoming calls that gets dropped. I will note it on my next post.
Our client is using SIP trunks.
Cheers,
Marvin
Hi Chris et al.,
End-User reported that it occured again at 12:37pm. Here's my log report, please help when you can:
P-RTP-Stat: PS=2,OS=160,PR=0,OR=0,PL=0,JI=0,LA=0,DU=0,EN=G711u,DE=G711u
Allow-Events: talk, hold, conference, x-spa-cti
Content-Length: 0
Oct 27 12:37:08 UC320W user.debug voice:
Oct 27 12:37:08 UC320W user.debug voice: [3:0]RTP Rx 1st PKT @16408(3)
Oct 27 12:37:08 UC320W user.debug voice: [3]<<10.1.1.1:5060(421)
Oct 27 12:37:08 UC320W user.debug voice: SIP/2.0 200 OK
To: ;tag=afcca31f7bf47798i5
From: GLASGOW RYAN <3236835319>;tag=829d11a7a2f29d7o3
Call-ID: 7d3e1896-c66d288b@108.207.191.249
CSeq: 103 BYE
Via: SIP/2.0/UDP 10.1.1.1:5083;branch=z9hG4bK-b7ba4c23
Server: Cisco/UC320W-2.1.2(1)
Content-Length: 0
Oct 27 12:37:08 UC320W user.debug voice: AUD:Stop PSTN Tone
Oct 27 12:37:08 UC320W user.debug voice: [3]<<10.1.1.1:6060(322)
To: <10.1.1.1>;tag=1a27709e-0
Call-ID: d7585704-c5a34f44@108.207.191.249
CSeq: 10233 NOTIFY
Via: SIP/2.0/UDP 10.1.1.1:5083;branch=z9hG4bK-c1fab404
Content-Length: 0
Oct 27 12:37:08 UC320W user.debug voice: [3:0]DEC INIT 0
Oct 27 12:37:08 UC320W user.debug voice: [4]->108.207.191.249:5060(489)
Oct 27 12:37:08 UC320W user.debug voice: BYE sip:fxo4@108.207.191.249:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.1:5084;branch=z9hG4bK-3553613e
3236835319¿ <10.1.1.1>;tag=e667624e59019f1bo4
To: ;tag=ec37ace3ca3d4d8ci5
Call-ID: 76f00c8a-91389a0f@108.207.191.249
CSeq: 103 BYE
Max-Forwards: 70
User-Agent: Cisco/UC320W-2.1.2(1)
P-RTP-Stat: PS=764,OS=183360,PR=763,OR=183120,PL=0,JI=0,LA=0,DU=23,EN=G711u,DE=G711u
Content-Length: 0
Oct 27 12:37:08 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:08 UC320W user.debug voice: [5]<<10.1.1.1:5084(489)
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:08 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:09 UC320W user.debug voice: TFTPS:<<6801010a:1378 /cfg/reports/spa504G_e05fb981b966.xmls
Oct 27 12:37:09 UC320W user.debug voice: TFTPS: Put
Oct 27 12:37:09 UC320W user.debug voice: report profile spa504G_e05fb981b966.xmls no change
Oct 27 12:37:09 UC320W user.debug voice: report address book spa504G_e05fb981b966.xmls no change
Oct 27 12:37:09 UC320W user.debug voice: [5]->108.207.191.249:6060(785)
Oct 27 12:37:09 UC320W user.debug voice: SIP/2.0 200 OK
To: ;tag=ec37ace3ca3d4d8ci5;ref=100
CSeq: 101 INVITE
Via: SIP/2.0/UDP 10.1.1.1:6060;branch=z9hG4bK-ac2a43d3__0
Via: SIP/2.0/UDP 10.1.1.1:5084;branch=z9hG4bK-ac2a43d3
Contact:
Content-Length: 216
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura, replaces
Content-Type: application/sdp
v=0
o=- 38015595 38015595 IN IP4 108.207.191.249
s=-
c=IN IP4 108.207.191.249
t=0 0
m=audio 16398 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
Oct 27 12:37:09 UC320W user.debug voice: [4]->10.1.1.1:6060(500)
Oct 27 12:37:09 UC320W user.debug voice: NOTIFY sip:10.1.1.1:6060 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.1:5084;branch=z9hG4bK-4cddca6c
To: <10.1.1.1>
Call-ID: f0f62890-c98ec113@108.207.191.249
CSeq: 7652 NOTIFY
Max-Forwards: 70
Event: fxo-port-state;fxo4;0;1;;;0;GLASGOW RYAN   ^B
3236835319¿;GLASGOW RYAN   ^B
3236835319¿;1;3;76f00c8a-91389a0f@108.207.191.249;108.207.191.249:5060;
Content-Length: 0
Via: SIP/2.0/UDP 10.1.1.1:5084;branch=z9hG4bK-cff0f3db
To: <10.1.1.1>
Call-ID: 58da28e7-a24b64a8@108.207.191.249
CSeq: 7652 NOTIFY
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:09 UC320W user.debug voice: [4]<<10.1.1.1:6060(726)
CSeq: 101 INVITE
Contact:
Content-Length: 216
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
Oct 27 12:37:09 UC320W user.debug voice: RespLooseMatch
Oct 27 12:37:09 UC320W user.debug voice: [4]->108.207.191.249:5060(442)
Oct 27 12:37:09 UC320W user.debug voice: ACK sip:fxo4@108.207.191.249:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.1:5084;branch=z9hG4bK-fa4909f8
CSeq: 101 ACK
Max-Forwards: 70
Contact: <10.1.1.1:5084>
Content-Length: 0
Oct 27 12:37:09 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:09 UC320W user.debug voice: [5]<<10.1.1.1:5084(442)
CSeq: 101 ACK
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:09 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:09 UC320W user.debug voice: TP Parser error: 14
Oct 27 12:37:11 UC320W user.debug voice: TFTPS:<<6a01010a:1568 /cfg/reports/spa504G_e05fb981af94.xmls
Oct 27 12:37:11 UC320W user.debug voice: TFTPS: Put
Oct 27 12:37:11 UC320W user.debug voice: ---- CC Active:
    TRK[5,12] CONNECTED
    FXO[3,-1]
Oct 27 12:37:11 UC320W user.debug voice: report profile spa504G_e05fb981af94.xmls no change
Oct 27 12:37:11 UC320W user.debug voice: report address book spa504G_e05fb981af94.xmls no change
Oct 27 12:37:12 UC320W user.debug voice: [4]->108.207.191.249:5060(489)
Oct 27 12:37:12 UC320W user.debug voice: BYE sip:fxo4@108.207.191.249:5060 SIP/2.0
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:12 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:12 UC320W user.debug voice: [5]<<10.1.1.1:5084(489)
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:12 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:13 UC320W user.debug voice: [5]->108.207.191.249:6060(785)
Oct 27 12:37:13 UC320W user.debug voice: SIP/2.0 200 OK
CSeq: 101 INVITE
Contact:
Content-Length: 216
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
Oct 27 12:37:13 UC320W user.debug voice: [4]->10.1.1.1:6060(500)
Oct 27 12:37:13 UC320W user.debug voice: NOTIFY sip:10.1.1.1:6060 SIP/2.0
To: <10.1.1.1>
CSeq: 7652 NOTIFY
Max-Forwards: 70
Content-Length: 0
To: <10.1.1.1>
CSeq: 7652 NOTIFY
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:13 UC320W user.debug voice: [4]<<10.1.1.1:6060(726)
CSeq: 101 INVITE
Contact:
Content-Length: 216
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
Oct 27 12:37:13 UC320W user.debug voice: RespLooseMatch
Oct 27 12:37:13 UC320W user.debug voice: [4]->108.207.191.249:5060(442)
Oct 27 12:37:13 UC320W user.debug voice: ACK sip:fxo4@108.207.191.249:5060 SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:13 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:13 UC320W user.debug voice: [5]<<10.1.1.1:5084(442)
CSeq: 101 ACK
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:13 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:13 UC320W user.debug voice: TP Parser error: 14
Oct 27 12:37:13 UC320W user.debug voice: TFTPS:<<6601010a:1376 /cfg/reports/spa504G_e05fb981b8c0.xmls
Oct 27 12:37:13 UC320W user.debug voice: TFTPS: Put
Oct 27 12:37:14 UC320W user.debug voice: report profile spa504G_e05fb981b8c0.xmls no change
Oct 27 12:37:14 UC320W user.debug voice: report address book spa504G_e05fb981b8c0.xmls no change
Oct 27 12:37:14 UC320W user.debug voice: [5]->10.1.1.1:5084(467)
Oct 27 12:37:14 UC320W user.debug voice: BYE sip:fxo4@10.1.1.1:5084;ref=fxo4 SIP/2.0
Via: SIP/2.0/UDP 108.207.191.249:5060;branch=z9hG4bK-5098f997
To: ;tag=e667624e59019f1bo4
CSeq: 101 BYE
Max-Forwards: 70
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=0,EN=G711u,DE=G711u
Content-Length: 0
Oct 27 12:37:14 UC320W user.debug voice: ++++ signaling events: 45 c0530 3b
Oct 27 12:37:14 UC320W user.debug voice: Voice CDR written
Oct 27 12:37:14 UC320W user.debug voice: DLG Terminated 5238cc
Oct 27 12:37:14 UC320W user.debug voice: [4]<<10.1.1.1:5060(467)
CSeq: 101 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:14 UC320W user.debug voice: [4]->10.1.1.1:5060(431)
Oct 27 12:37:14 UC320W user.debug voice: SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
Oct 27 12:37:14 UC320W user.debug voice: DLG Terminated 52407c
Oct 27 12:37:14 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:14 UC320W user.debug voice: [5]<<10.1.1.1:5084(431)
CSeq: 101 BYE
Content-Length: 0
Oct 27 12:37:14 UC320W user.debug voice: ++++ signaling events: 80 c0530 518420
Oct 27 12:37:14 UC320W user.debug voice: DLG Terminated 523a14
Oct 27 12:37:14 UC320W user.debug voice: Sess Terminated 424a6fb8
Oct 27 12:37:14 UC320W user.debug voice: ++++ signaling events: 80 c4001 0
Oct 27 12:37:14 UC320W user.debug voice: DLG Terminated 524f38
Oct 27 12:37:14 UC320W user.debug voice: Sess Terminated 42495c38
Oct 27 12:37:16 UC320W user.debug voice: [4]->108.207.191.249:5060(489)
Oct 27 12:37:16 UC320W user.debug voice: BYE sip:fxo4@108.207.191.249:5060 SIP/2.0
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:16 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:16 UC320W user.debug voice: [5]<<10.1.1.1:5084(489)
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:16 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:20 UC320W user.debug voice: [4]->108.207.191.249:5060(489)
Oct 27 12:37:20 UC320W user.debug voice: BYE sip:fxo4@108.207.191.249:5060 SIP/2.0
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:20 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:20 UC320W user.debug voice: [5]<<10.1.1.1:5084(489)
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:20 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:24 UC320W user.debug voice: [4]->108.207.191.249:5060(489)
Oct 27 12:37:24 UC320W user.debug voice: BYE sip:fxo4@108.207.191.249:5060 SIP/2.0
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:24 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:24 UC320W user.debug voice: [5]<<10.1.1.1:5084(489)
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:24 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:26 UC320W user.debug voice: ---- CC Active:
    FXO[3,-1]
Oct 27 12:37:28 UC320W user.debug voice: [4]->108.207.191.249:5060(489)
Oct 27 12:37:28 UC320W user.debug voice: BYE sip:fxo4@108.207.191.249:5060 SIP/2.0
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:28 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:28 UC320W user.debug voice: [5]<<10.1.1.1:5084(489)
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:28 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:30 UC320W user.debug voice: [9]RegOK. NextReg in 118 (1)
Oct 27 12:37:32 UC320W user.debug voice: [3:0]LAT-- 6(3)
Oct 27 12:37:32 UC320W user.debug voice: [4]->108.207.191.249:5060(489)
Oct 27 12:37:32 UC320W user.debug voice: BYE sip:fxo4@108.207.191.249:5060 SIP/2.0
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:32 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:32 UC320W user.debug voice: [5]<<10.1.1.1:5084(489)
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:32 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:36 UC320W daemon.info hostapd: ath0: STA 00:19:e3:da:ec:2e WPA: group key handshake completed (RSN)
Oct 27 12:37:36 UC320W daemon.info hostapd: ath0: STA e4:ce:8f:38:80:76 WPA: group key handshake completed (RSN)
Oct 27 12:37:36 UC320W user.debug voice: [4]->108.207.191.249:5060(489)
Oct 27 12:37:36 UC320W user.debug voice: BYE sip:fxo4@108.207.191.249:5060 SIP/2.0
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:36 UC320W user.debug voice: SIP msg from private user
Oct 27 12:37:36 UC320W user.debug voice: [5]<<10.1.1.1:5084(489)
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
Oct 27 12:37:36 UC320W user.debug voice: TP Parser error: 9
Oct 27 12:37:38 UC320W user.debug voice: [3]<<10.1.1.106:5060(482)
Oct 27 12:37:38 UC320W user.debug voice: BYE sip:3236835319@10.1.1.1:5083;ref=fxo3 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.106:5060;branch=z9hG4bK-be31ff70
To: "GLASGOW RYAN" <3236835319>;tag=22e9449bf535e683i3
Call-ID: 48b0cd5f-2a344c5d@10.1.1.106
CSeq: 102 BYE
Max-Forwards: 70
User-Agent: Cisco/SPA504G-7.4.7v23
P-Mailbox: 5100
P-RTP-Stat: PS=995,OS=238800,PR=995,OR=238800,PL=0,JI=0,LA=0,DU=30,EN=G711u,DE=G711u
Content-Length: 0
Oct 27 12:37:38 UC320W user.debug voice: [3]->10.1.1.106:5060(458)
Oct 27 12:37:38 UC320W user.debug voice: SIP/2.0 200 OK
CSeq: 102 BYE
P-RTP-Stat: PS=1001,OS=240240,PR=1001,OR=240240,PL=0,JI=0,LA=0,DU=30,EN=G711u,DE=G711u
Content-Length: 0
Oct 27 12:37:38 UC320W user.debug voice: CC:Ended
Oct 27 12:37:38 UC320W user.debug voice: Voice CDR written
Oct 27 12:37:38 UC320W user.debug voice: AUD:Stop PSTN Tone
Oct 27 12:37:38 UC320W user.debug voice: [3:0]AUD Rel Call
Oct 27 12:37:38 UC320W user.debug voice: FXO[3]:On Hook
Oct 27 12:37:38 UC320W user.debug voice: FXO[3]:Stop CNDD
Oct 27 12:37:38 UC320W user.debug voice: FXO[3]:Report:sesssion=424c7448;cst=0
Oct 27 12:37:38 UC320W user.debug voice: [3]->10.1.1.1:6060(435)
Oct 27 12:37:38 UC320W user.debug voice: NOTIFY sip:10.1.1.1:6060 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.1:5083;branch=z9hG4bK-4358e73e
To: <10.1.1.1>
Call-ID: edd627d2-38d41089@108.207.191.249
CSeq: 13236 NOTIFY
Max-Forwards: 70
Event: fxo-port-state;fxo3;0;0;;;1;;;1;4;48b0cd5f-2a344c5d@10.1.1.106;10.1.1.106:5060;
Content-Length: 0
Oct 27 12:37:38 UC320W user.debug voice: audio restart
Oct 27 12:37:38 UC320W user.debug voice: [3]<<10.1.1.1:6060(322)
CSeq: 13236 NOTIFY
Content-Length: 0
Oct 27 12:37:38 UC320W user.warn kernel: Closing pcm device
Oct 27 12:37:38 UC320W user.warn kernel: PHONE_REC_STOP
Oct 27 12:37:38 UC320W user.warn kernel: PHONE_PLAY_STOP
Oct 27 12:37:38 UC320W user.debug voice: aud restarted(50ms)
Oct 27 12:37:38 UC320W user.warn kernel: PHONE_PLAY_START
Oct 27 12:37:38 UC320W user.warn kernel: CPLD indication triggered - Tx/Rx started ok
Oct 27 12:37:38 UC320W user.warn kernel: PHONE_REC_START
Oct 27 12:37:38 UC320W user.warn kernel: Opening pcm device
Oct 27 12:37:39 UC320W user.debug voice: DLG Terminated 524c04
Oct 27 12:37:39 UC320W user.debug voice: DLG Terminated 522f30
Oct 27 12:37:39 UC320W user.debug voice: DLG Terminated 5241c4
Oct 27 12:37:39 UC320W user.debug voice: Sess Terminated 424cdb98
Oct 27 12:37:39 UC320W user.debug voice: DLG Terminated 52430c
Oct 27 12:37:39 UC320W user.debug voice: Sess Terminated 424c0cf8
Oct 27 12:37:40 UC320W user.debug voice: DLG Terminated 524120
Oct 27 12:37:40 UC320W user.debug voice: Sess Terminated 424c51d8
Oct 27 12:37:43 UC320W user.debug voice: TFTPS:<<6a01010a:1569 /cfg/reports/spa504G_e05fb981af94.xmls
Oct 27 12:37:43 UC320W user.debug voice: TFTPS: Put
Oct 27 12:37:43 UC320W user.debug voice: report profile spa504G_e05fb981af94.xmls no change
Oct 27 12:37:43 UC320W user.debug voice: report address book spa504G_e05fb981af94.xmls no change
Oct 27 12:37:46 UC320W user.debug voice: DLG Terminated 52363c
Oct 27 12:37:46 UC320W user.debug voice: Sess Terminated 424c2f68
Oct 27 12:38:10 UC320W user.debug voice: DLG Terminated 524df0
Oct 27 12:38:10 UC320W user.debug voice: Sess Terminated 424c7448
Oct 27 12:38:11 UC320W user.debug voice: CC:Clean Up
Oct 27 12:38:11 UC320W user.debug voice: --- OBJ POOL STAT ---
Oct 27 12:38:11 UC320W user.debug voice: OP:RTPRXB =  96 ( 96  192)
Oct 27 12:38:11 UC320W user.debug voice: OP:RTPREB =  40 ( 40   48)
Oct 27 12:38:11 UC320W user.debug voice: OP:RTPTXB =  64 ( 64  108)
Oct 27 12:38:11 UC320W user.debug voice: OP:TIMEOU = 133 (163   52)
Oct 27 12:38:11 UC320W user.debug voice: OP:SIPCOR =   0 (  1   32)
Oct 27 12:38:11 UC320W user.debug voice: OP:SIPCTS =  48 ( 48  624)
Oct 27 12:38:11 UC320W user.debug voice: OP:SIPSTS =  63 ( 71 6076)
Oct 27 12:38:11 UC320W user.debug voice: OP:SIPAUS =   8 (  8  680)
Oct 27 12:38:11 UC320W user.debug voice: OP:SIPDLG =  58 ( 58  164)
Oct 27 12:38:11 UC320W user.debug voice: OP:SIPSES =  40 ( 40 8816)
Oct 27 12:38:11 UC320W user.debug voice: OP:SIPREG =  16 ( 26  468)
Oct 27 12:38:11 UC320W user.debug voice: OP:SIPLIN =   0 ( 15  148)
Oct 27 12:38:11 UC320W user.debug voice: OP:SUBDLG =   2 ( 10 6740)
Oct 27 12:38:11 UC320W user.debug voice: OP:STUNTS =  32 ( 32   68)
Oct 27 12:38:11 UC320W user.debug voice: OP:SIPCTI =   1 (  9 7428)
Oct 27 12:38:11 UC320W user.debug voice: OP:XMNODE = 1024 (1024  112)
Oct 27 12:38:22 UC320W daemon.info hostapd: ath0: STA 8c:58:77:2d:94:83 IEEE 802.11: associated
Oct 27 12:38:23 UC320W daemon.info hostapd: ath0: STA 8c:58:77:2d:94:83 WPA: pairwise key handshake completed (RSN)
Oct 27 12:38:23 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:38:24 UC320W user.notice udhcpd: DHCP Thu, 27 Oct 2011 12:38:24 received REQUEST from 8C:58:77:2D:94:83
Oct 27 12:38:24 UC320W user.notice udhcpd: DHCP Thu, 27 Oct 2011 12:38:24 sending ACK to 192.168.1.19
Oct 27 12:38:27 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:38:35 UC320W daemon.info hostapd: ath0: STA 8c:58:77:2d:94:83 IEEE 802.11: disassociated
Oct 27 12:38:49 UC320W user.debug voice: CHECK: type = 0, idle_timer = 0, delayed_count = -1, clock = 38031262, flag = 0, event = 4
Oct 27 12:39:28 UC320W user.debug voice: [9]RegOK. NextReg in 118 (1)
Oct 27 12:40:00 UC320W cron.info cron[20833]: (root) CMD (/sbin/check_ps)
Oct 27 12:40:26 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:40:27 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:40:29 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:40:42 UC320W user.info VOICECDR: DEBUG source/voice_cdr_logger.c:358 voicecdr_timer_flush_thread: Trying to grab flush mutex
Oct 27 12:40:42 UC320W user.info VOICECDR: DEBUG source/voice_cdr_logger.c:369 voicecdr_timer_flush_thread:Grabbed flush lock
Oct 27 12:40:42 UC320W user.info VOICECDR: DEBUG source/voice_cdr_logger.c:370 voicecdr_timer_flush_thread: Trying to grab disk access config mutex
Oct 27 12:40:42 UC320W user.info VOICECDR: DEBUG source/voice_cdr_logger.c:372 voicecdr_timer_flush_thread: Grabbed disk access config mutex
Oct 27 12:40:42 UC320W user.info VOICECDR: DEBUG source/voice_cdr_logger.c:327 Put 4 CDRs on disk/flash in file /home/usb_disk/cdr/voicecdr.10272011-12-30-42.xml
Oct 27 12:40:42 UC320W user.info VOICECDR: DEBUG source/voice_cdr_logger.c:378 voicecdr_timer_flush_thread: Release disk access config mutex
Oct 27 12:40:42 UC320W user.info VOICECDR: DEBUG source/voice_cdr_logger.c:380 voicecdr_timer_flush_thread: Released flush mutex
Oct 27 12:40:55 UC320W daemon.info hostapd: ath0: STA 8c:58:77:2d:94:83 IEEE 802.11: associated
Oct 27 12:40:55 UC320W daemon.info hostapd: ath0: STA 8c:58:77:2d:94:83 WPA: pairwise key handshake completed (RSN)
Oct 27 12:40:55 UC320W user.notice udhcpd: DHCP Thu, 27 Oct 2011 12:40:55 received REQUEST from 8C:58:77:2D:94:83
Oct 27 12:40:55 UC320W user.notice udhcpd: DHCP Thu, 27 Oct 2011 12:40:55 sending ACK to 192.168.1.19
Oct 27 12:41:26 UC320W user.debug voice: [9]RegOK. NextReg in 118 (1)
Oct 27 12:41:29 UC320W daemon.info hostapd: ath0: STA 8c:58:77:2d:94:83 IEEE 802.11: disassociated
Oct 27 12:42:31 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:42:37 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:43:24 UC320W user.debug voice: [9]RegOK. NextReg in 118 (1)
Oct 27 12:43:49 UC320W user.debug voice: CHECK: type = 0, idle_timer = 76, delayed_count = -1, clock = 38061262, flag = 0, event = 4
Oct 27 12:44:37 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:44:43 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:44:44 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:45:09 UC320W user.notice udhcpd: DHCP Thu, 27 Oct 2011 12:45:09 received REQUEST from 00:16:76:B1:13:AF
Oct 27 12:45:09 UC320W user.notice udhcpd: DHCP Thu, 27 Oct 2011 12:45:09 sending ACK to 192.168.1.20
Oct 27 12:45:22 UC320W user.debug voice: [9]RegOK. NextReg in 118 (1)
Oct 27 12:46:44 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:46:45 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:46:52 UC320W user.debug kernel: sysevt_comm_sendto: (60, rc)=>
Oct 27 12:47:20 UC320W user.debug voice: [9]RegOK. NextReg in 118 (1)
Have you run the Impedence Matching on each of your FXO ports?  It looks like there is some "garbage" in the caller ID from the FXO which indicates there may be some line environment issues:
3236835319¿
Impedence matching instructions can be found inn the UC320W Troubleshooting Guide:
https://supportforums.cisco.com/docs/DOC-16469
Chris
TJMerittech
Marvin,
I am currently experiencing the same issue exactly as discribed except only its happening to me on fxo. Just wondering if you had found a fix to this.
