UC320W VM to Email issue
Todd Vohs
I was having problems getting my voice mail to email working with my ISP and had I read on another post that the UC320W supports port 587 with Google's gmail.  I set the parameters to use my gmail account and they are actually the same as the parameters to get MS Outlook to work with it.  I logged into Google with the same credentials to verify that I had the correct password and am still receiving this:
Feb 10 14:25:12 UC320W daemon.info sendmail: smtp_checkp check AUTH LOGIN with code -1
Feb 10 14:25:12 UC320W daemon.info sendmail: smtp_checkp get answer 334 VXNlcm5hbWU6
Feb 10 14:25:12 UC320W daemon.info sendmail: smtp_checkp check  with code 334
Feb 10 14:25:12 UC320W daemon.info sendmail: smtp_checkp get answer 334 UGFzc3dvcmQ6
Feb 10 14:25:12 UC320W daemon.info sendmail: smtp_checkp check  with code 235
Feb 10 14:25:13 UC320W daemon.info sendmail: smtp_checkp get answer 535-5.7.1 Username and Password not accepted. Learn more at
Feb 10 14:25:13 UC320W daemon.info sendmail: smtp_checkp get answer 535 5.7.1 http://support.google.com/mail/bin/answer.py?answer=14257 mr24sm13599225ibb.1
Feb 10 14:25:13 UC320W daemon.err sendmail: Authendication failed
Any ideas on what would still cause this?  The link is an invalid page on Google's site.
Thanks in advance,
Todd.
Thanks, Todd Vohs Owner Holstein Ag Services, LLC
Todd Vohs
BTW, if I use my ISP (without SSL/TLS) on port 25, the UC320W shows the following:
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp check (NULL MSG) with code 220
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 220 *********************************************
Feb 10 14:51:31 UC320W daemon.info sendmail: sendgetmail_main get WAN ip [10.1.2.100] as EHLO identify
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp check EHLO [10.1.2.100] with code -1
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 250-relay03.dlls.pa.frontiernet.net
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 250-PIPELINING
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 250-SIZE 26214400
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 250-ETRN
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 250-AUTH LOGIN PLAIN
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 250-AUTH=LOGIN PLAIN
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 250-ENHANCEDSTATUSCODES
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 250-8BITMIME
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 250 DSN
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp check AUTH LOGIN with code -1
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 334 VXNlcm5hbWU6
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp check  with code 334
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp get answer 334 UGFzc3dvcmQ6
Feb 10 14:51:31 UC320W daemon.info sendmail: smtp_checkp check  with code 235
Feb 10 14:51:32 UC320W daemon.info sendmail: smtp_checkp get answer 535 5.7.8 Error: authentication failed: authentication failure
Feb 10 14:51:32 UC320W daemon.err sendmail: Authendication failed
I can ping these servers from the UC320W and it has full connectivity all around.
Hi Todd,
Make sure you are only using a Google password with numbers and letters.  There is a known bug where special characters like $ in your password will cause authentication to fail.  I believe it is fixed in the 2.2 release coming out soon.
Chris
